issues with my vrs
hi guys
ive got a slight knocking noise in 1st and started in secong lightly clutch slip slightly between 3k and 4k any ideas as the car just past its mot fine last week
de cat is it worth it and how do u go about mot and such
many dan
sounds like the clutch is on ts way out new clutch needed
decat is okay if you have access to a friendly mot tester ;) or you will have to put cat back on before the mot agro lol
cars only done 37k and first owner was a family i drive her strong but not hard
but if you say the clutch is slipping then im afraid its a new clutch
give it some beans and see what it does the speed should rise the same as the revs if the revs rise but you go no where then new clutch is needed mileage means nothing buddy some cars last 100+ k some last 30k luck of the draw
a sunday blast it is il let ya know
Hand break on out it into 2nd and start letting the clutch out.
You will soon know if its clutch slipping and if it just stalls the car then its fine.
If the sounds your getting if cinda knocking /rattay then could be your mass fly wheel.
hey guys on closer inspection and a good test drive no slipping just me being paranoid
check over the front end and the cv gaitor has come off slighty and gone dry thank god soo while i was there i cleaned up and dropped my coilovers abit but then come over a new problem both sides have got the same amount of thread on each side but one side is higher back and front is this weird
engine weight at the front is not evenly spread so one side will have to be on a lower thread :thumbup:
but its front and back passenger tho
