Spax RSX or Weitec Hicon GT Coilover
Hi all
Well about to order some monday but what 1s are better.
Weitec Hicon GT Coilover Suspension Kit
Octavia 1U 1.8T 4x4 01/99>
Part Number: 13280031
Front Lowering: 30-50mm
Rear Lowering: 30-50mm
Front Axle Weight: Up to 1030kg
Rear Axle Weight: Up to 1070kg
High performance twin tube design dampers
Galvanized strut housing with additional coating for ideal corrosion prevention
Individually height adjustable
German TUV tested lowering range
High quality components for long life
Or
Spax RSX Coilover Suspension Kit
Part Number: RSX862
Front Lowering: 25-55mm
Rear Lowering: 25-55mm
On car adjustment of bump and rebound damping
Cool looks with a sportier ride thats ideal for fast road and track use
Gas pressurised dampers for superior comfort and absolute performance
Built in front bump stops and helper springs
Powder coated for long life and stunning looks
Thinking spax more as i can change hight and damping?
What do you think.
Prices?
I have Weitecs and they are brill. only 2wd tho.
depending on the price I would go Spax because of the stuff you can do but......... are you of a good mech mind? do you know what you are doing when it comes to tuning suspension? if not Id just go for ones that are ready for you.
Simple option might be better.
again all down to price too.
Prices?
Spax for £606 +posting
Weitecs about the same
And will have np it setting them up and have full accsese to ramps and tools.
  • Sponsor
Personally I prefer the Weitec kits.
Damian @ DPM Performance
x2,
havin had the spax rsx before and now havin the weitec's i would go with those unless your goin to be trackin/racin the car then thats different as you can fine tune the spax although ive found the handlin and cornering with the weitec kit fantastic :thumbup:
So the adjustment of bump and rebound damping on the spax would be somthing like full open for a hard ride not very comfy to full closed for the ride to like having a bar welded in as your shock lol.
Right thats the Weitec Hicon GT Coilover orderd :D
Thx damian for helping make my mind up.
Cant wate to get them now :-)
Weitecs are excellent. :thumbup:
Should be fun the 1st time out on them as the roads up here about glasgow are bumby as hell right now :-)
2nd taht.
when I was up doing resettlement last year at Ritchies HGV place the roads were shocking.
