Cant find this part number
Been searching but going to have to post.
Its the common hose that splits under the inlet manifold which is wrapped together with another hose that goes to the T section.
Can you buy that hose seperate because I tried to explain it to the steelers but need to make sure its the right one before I order it. Sure its called a vacuum hose of some sort.
Thanks.
Is this it? 06A 103 221 BK
Edited by Stakeknife
just got the aswome set myself as the y-piece had split badly, but the one under neith is fine and looks like hard work to change!! so that ones staying in the shed till it has to be changed!
Ive already changed the top one, couldnt afford the silicone ones at the time, although wish I could of.
The bottom one I just changed wasnt to bad, a bit fiddly but they all are, and I have no patience!! A good hour should see you done and cleaned up. The hard part is just getting the old clips off.
top one nice and easy, replaced with Jubile clips much easyer to use bottom one looks like u need small arms to get in there!
