Roof Leak
Hi all. New problem. My head lining inside the car front left is drenched. The wetness can be seen starting from the top of the passenger door (front), travels towards the windscreen and then across the top almost to the middle. There is also a slight wet patch where the grab handle above the passenger door left (rear). I was thinking this maybe the rubber lining that is sat in the groove of the body work which the roof bar is fixed to. I also think the sun roof maybe leaking from behind as well as the front of the sun roof is completey dry.
Any words of wisdom would be appreciated.
blocked drain for the sunroof?
ummmmm it seems odd how the wet patch is at the left of the roof and not the right
Could someone tell me what and where the A piller is please
The A pillars are the two pillars either side of the windscreen.
B pillars are the ones between the front and rear doors, and so on.
