simple help
hi all im new here so firstly hello
now im trying to find out if i can use vagcom to read my skoda as i have been told i can i think its v311.
and secondly where is the port to connect the vagcom lead in..??
thanks all regards sean
You should be able to get VCDS (as vagcom is now known) to check your car over and you'll find the connection plug is the diagnostic plug which is purple in colour and located under the dashboard just above the bonnet release handle.
Ian
