skoda octavia
hi guys i ahve a problem with my car which i bought last week, the speedometer is not working only half of the part working( which shows us the speed of the car not working) and after few miles drive oil light giving me signal!! can somebdy help me about this. wht could be the problem and how to sort out? please
Speedo sensor could be dead or it could be a dashboard failure. As for the oil light coming on, have you checked the oil level?
yes i check oil and all, evrything is perfect, and also fuel gauge also going up and down!! do u know anything about VAG COM ? would it help me ?
Vag com should be able to tell if it's a dashboard failure, which is the most likely cause of the problem, I'd remove the dash & check the connectors are seated properly.
Have you still got this problem ? :thumbdown:
If you have pm me your email and ill send you a octavia dash repair manual that might help. :thumbup:
Bazaa
