Bury CC9060 to Occy2
Ok, got a Bury CC9060 to fit to my Occy 2 with MFD2.
Got adaptor lead from Autoleads ~ SOT-976.
Plugged adaptor lead to bury switchbox leads.
Swapped over red & blue cables on DC power supply leads....Configuration 2 ~ I assume correct (as Pin 4 is permanent +ve and Pin 7 is ignition switched +ve) ?
Plugged Yellow from switchbox into Mute 2 as Mute is on Pin 2 ~ Correct ?
Plugged all other bits together.
Switched on ignition.......Nothing !!!!!
Am I missing something ?
There's a Red cable hanging from adaptor lead but did not connect this....should I ?
Should Bury screen come to life when plugged into the holder ?
Fortunately just lashed all this up without fully installing, just to see if it worked ok. Now stuck still with old Nokia.
Any advice appreciated as old Nokia system has awful echo for callers.
Can't help at the moment - but I'm about to install the exact same system one evening this week. So I'll keep the above info in mind and see if I can help.
Steve
Steve
Spot on Steve......need to find out where I'm going wrong n any tips appreciated.
Going out but will check later.............
I was beginning to think no one else was using this setup.
Rgds....Bob
