Columbus aerial connectors
I've just swapped my Audience head unit out for a Columbus, but I've a problem with the aerial connectors. My Audience has 2 separate aerial connectors. The Columbus also has 2, but they are so close together that I cannot fit both the connectors in my dash to it. I guess it's subtly different!
Can anyone tell me what I need to fit the aerials?
Thanks .
Thanks .
could you not buy the extended type aerial connectors, quite hard to explain but they have connectors on them and then a bit of cable with theplug in further down the line so they are not mounted next to one another
I believe you may need somthing like this from Kufatec
Kufatec Antenna adaptors
HTH
Edited by InexEng
That looks exactly like what I need. €24.99 plus shipping, though :o
Apparently there is a VW part this same as this - 7L6 051 551.
I'll see if that helps my local Skoda dealer order the part.
