Replacing Aerial base?
Hi guys,
just realised my FM problems are being caused by a faulty aerial base...
Does anyone have a step by step guide to fully replace the aerial???
I'm a bit confused here. I also removed the mast by pulling on the thing. Is it possible to replace the mast? or will i need to buy a whole new unit?????
Edited by Beancounter1980
Whole complete aerial unit (base and antenna) cost me about £42.00 approx 3 years ago from Skoda parts dept, for my 2005 Fabia VRS.
Open tail gate, pull back/away rubber tail-gate seal, pull head-lining downwards, this will reveal aerial base and cable connection to front of car.
Disconnect aerial cable, 10mm spanner to undo aerial base nut and remove.
There's a PCB in the Aeriel base, Which is killed when water gets in!
Edited by Mike B
