tickover
is it possible to turn up the tickover on my skoda superb,2.5 tdi v6,car is the bdg motor,2004if through vagcom etc how is it done?
Why do you want to do this?
car has a misfire at tickover,the misfire is a result of the throttle body flap shutting as though its going to stop and then it carrys on ok,not sure whats causing this to happen but i think the tickover is too low,around 730rpm
Check the vacuum solenoid for the throttle body actuator. There should be no vacuum going from the vac actuator to the throttle body with the engine running.
The throttle body on these is only used during shutdown to stop engine shake. You can hear a brief whoosh as you turn the ignition to OFF as it chokes the
engine to a halt.
engine to a halt.
interesting thought that because i am sure the misfire is when the throttle body tries to flick shut for a split second,look at that over weekend,cheers for the info mate.
