Bumper removal
Does anyone have a bumper removal guide for a front bumper (pre facelift)
cheers
Mike, don't suppose you've got the vRS rear bumper removal guide? :yes:
Hope this helps.
Pages from ElsaWin as pdf.
Mike
Thanks Mike thats great :thumbup:
I was going to use the rear bumper removal guide from here
Although if there is another guide like the one above it will also be handy to have
Edited by matt@theforce
Matt,
I'm guessing that this bumper removing/fitting fest will require a few photos of the end result :yes: :thumbup:
Don't say I don't try!
Here's the one for the rear bumper!
Mike
Thanks again Mike.
Matt,
lol, it will indeed... although I need to get a few more bits before I can get them fitted, I'm making an Octavia SE (Special Elegance), Now. Wheres that lottery ticket from last night :thumbup:
edit.. not a single winning line in 18lines :(
  • 4 weeks later...
On this issue, does anyone know (or able to work out) if the vRS bumper sticks out a bit further than the std one?
Medium term plan is to fit a vRS rear bumper to my Elegance as I prefer the smoothed look. I think it's 'filled out' a bit more though. So just wondering about exhaust finishing, so that they will sit right in the cutout when I come to swap.
Cheers,
Steve
Cheers,
Steve
Looking at a neighbours I 'think' they are the same, I will measure them if I can, my neighbour will think I'm nuts but hey ho! :thumbup:
Cheers,
Steve
Steve,
I'm popping upto a friends on the 19th (he has a huge warm dry garage) for the fitting of my bumpers, I can get some measurements and pics then for you :thumbup: . I dont think the front or back stand out much further (if any) from the ends of the car however the rear is a little more squarer which I wanted as it curves the opposite way to the elegance bumper so will hopefully hide the towbar and electrics a little more.
If you look in the accessories cataloge there is different part numbers for the exhaust tailpipe trims depending on having the sport or normal bumpers fitted, I'm guessing this is down to extra low down lenth of the bumper.
Matthew
Thanks, that would be good :thumbup:
Perhaps I didn't explain it very well. I don't think it sticks out further overall, more that it's 'fuller' throughout it's total height on the car, if that makes sense.
So there's more to it, around the pipes and also as you say, around the towbar area for you.
Spot on comment about the Accessories catalogue items too; I'd noticed there were two versions and my feeling was the same as yours.
The 19th might be a little late, as I'll have my exhaust fitted by then (hopefully!) but it would be good to maybe have measurements and also the difference in how far your std pipes stick out, with the Elegance bumper on and then with the vRS one.
Cheers,
Steve
Steve, my Sport bumpers def sat out further than the Standard bumpers, Im pretty certain the same applies to the VRS bumpers!
Elegance Bumper besides vrs bumper
Elegance bumper showing towbar cutout comes up the rear of the bumper
Vrs bumper showing towbar cutout doesn't come up the rear of the bumper
I dont think there is alot in it but the vrs certainly has a squarer shape to the bottom
Thanks guys.
Yes, this is the point I think - squarer at the bottom.
Cheers for that mate. Any idea of how much? Say by comparison, of how much further in the std TDI pipes sat, with the Sport bumper fitted?
Surely if its a custom made system they will be able to adjust the tailpipe to suit when you have your vrs bumpers fitted? understandably there is probably a cost involved but it might be better than getting your tailpipes set further out of the bumper before you get your vrs bumpers!
Oh yeah, absolutely. Just wondered about the actual difference, so I could decide which way to do it really :)
