AP Brakes
I have a found a set of AP brakes from 07 mk3 Ibiza 160 PD Curpa
I am looking to know will these fit under stnadard 16 inch fabia wheels?
are they a direct fit anyone here tried it
Cheers Inkey
unlikely, they're wide calipers and cause big problems getting non-standard wheels onto a Cupra :thumbdown:
would they fit with spacers?
bump anyone any ideas cheers
Doubt it... Only way to know is to try it
As they use 312mm discs may fit under 16's but its the width thats the issue
May req 20-25mm spacers which may make the wheel hit the arch
they may use 312mm discs.. but the calipers are huuuge.
you need a min of 17" and some serious gap between standard caliper and spokes.
there bigger than 323mm brembos
