KENWOOD DNX5220BT
Will it fit a MK1 fabia? I.E straight in.. also if anyone is using one of these what else do i need fascia adapters etc
bump
awesome mate, you know if it will fit?
The fascia infill part (top bit only between the top of any DIN unit and the row of fascia buttons)....yes it does fit as designed by Skoda for the retro-fitting of DIN units to Fabia MK1....I have it fitted as I have a Pioneer DIN size heatunit B)
I mean the head unit buddy as im clueless :rofl:
It's a Friday...you've got weekend brain!! :rofl:
If it's a standard 2DIN size then yes....just remove the cubby or draw below the OEM headunit....and hey presto a full size 2DIN OEM space is revealed !! B)
EDIT
Just looked at their installation book for it
http://images.kenwood.eu/files/prod/1032/5/installation_manual_(EN).pdf
No problems!!!
BUT remember when fitting the wiring harness and make sure that the OEM Skoda wiring loom and the Kenwood one have the correct wires joining up....they are in their book (as in most retro-fit) stating to swap several wires on their loom if the Skoda OEM does not line up
Use my post to check against!! B)
http://briskoda.net/forums/topic/196288-oem-wiring-loom-colours-pins-for-stereos/
Edited by fabdavrav
thanks a lot mate i was of the idea that all 2 din fitted all 2 din slots just checking :p :thumbup:
