CECM Problem Please Help
Hi I have had a guy check my car and has told me the CECM central electronic control module is damaged. I had the known issue with the water in the car and has likely caused this.
Any idea where the location of this module is so i can get part number to replace or does anyone here know the part number and what the cheapest option is.
Any advice or help to get this resolved will be appreciated.
thanks
isnt it under the carpet under the seat?
This may help, as it is a VCDS scan taken from my 2004 Superb Comfort:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: BE Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00028
Part No: 1C2959802
Component: BE Tõrsteuer.FS KLO 0202
Part No: 1C2959801
Component: BE Tõrsteuer.BF KLO 0202
Part No: 3U0959811
Component: BE Tõrsteuer.HL KLO 0202
Part No: 3U0959812
Component: BE Tõrsteuer.HR KLO 0202
No fault code found.
You need to remove the passenger seat (disconnect the battery before you unplug the seat airbag and do not turn the ignition on with the seat removed or you will have the airbag light on the dash and will need VCDS or a dealer to turn it off again!) once the seat is out lift the carpet and the CCM is under there.
