Weird dash lights came up today
Hi folks, must be my month for problems.
Can't have Billy having all the issues can we :giggle:
I had the red brake light flashing and ABS light and that triangle light illuminated today
Ran hand held diagnostics and got
- Voltage supply kl.30 voltage too low.
- Powertrain Data Bus: Missing Message from ABS Controller
left it for a while and needed to go to shops now all is ok.
What went on there then. Now I have been playing with Fans and aircon last week to fix fans and have battery off and perhaps a connection or earthing issue cropped up, who knows..
Will keep a eye out and see if it re appears.
The two green fuses on the top of the battery that don't go to the fan controller, go to the ABS unit.
Cheers buddy, it all makes sense now. I swapped those around, so the fuse causing initial issue to the fans last week is now in the ABS socket. Even though the fuse looks ok there must be a hairline crack or something. Will replace all 3 tomorrow.
Appreciate your spot on advise.... :thumbup:
