Brakes problems
I am getting brake grinding noise since i changed my wheel bearing. The disc and pads are new plus changed the abs sensor still no fix. It only makes grinding noise when i am doink 20 and brake gently. Any ideas? Can it be brake fluid>
Is it from the front or back?
What car do you have?
is the front brake and its skoda octavia 03 plate diesel
just reaslised when i press clutch and brake at the same time, thats when it makes grinding noise. if i hit brakes hard on its on, car stop fine without any issues. any suggestions?
Seems similar to noses mine makes on light braking, particularly when changing gear and cornering at low speed.
Only thing found so far that might contribute to noise is a tiny bit of play in the NSF wheel bearing. Odd as noise isn't restricted to left of the car.
