HELP : cruise instal not responding
iv installed cruise into my 1.9 diesel octavia 03 reg...
all wiring in and did the following on VAG-com ...
Enable the ECU for Cruise Control using VAG-COM or similar. Note that this procedure does not require the registered version of VAG-COM :
[select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
And im getting nothing. Iv checked and i have 13V power going to the stalk
is thier another fuse somewhere that i should check ? fuse 5 that i tapped into is fine
Confused.com
Edited by Tim_davies-moss
Anyone know where the wire goes from the bulkhead under the wiper motor ?? ... ... its a diesel and want to check iv got continuity of power from the cruise switch to the furthest point it goes too ???
They go from the relay/fuse box under wiring asm to the ECU.
follow the pdf install guide on here if it helps
http://vwgolfr32.co.uk/ccs.pdf
When you cheched VAGCOM did you get the "G" in the main component field that indicates cruise has been activated succesfully?
I took some pics when i installed cruise control and of under the wiper asm, removing that lot is a pain.
hope this helps
Yes.. the G is now within the text of the car details so im hoping thats that done
im just so confused now as to why its still not working
want to check wiring continuity... iv got a live feed ( confirmed ) and the switch is giving a switched + towards the loom
just want to check the furthest point of the loom now to see if the signal + is getting through
i know iv got the wires from the Black block under the wiper motor to the engine control unit but i want to check the power is getting through
so.. where is this engine control unit please ???
Won't vcds tell you if.you look at a measuring block if the signal is getting to the ecu?
is that VAG-com ?? or do i need a skoda machine to do that ?
Yes, VAG "asked" RossTech not to use VAGCom as a name, so it's called VCDS now instead. It's the same thing.
GOTCHA... ill try that then
i did plug the laptop up to the car today but VCDS kept crashing... although it worked for 5 mins the other day to enable the cruise in the ECU
thanks for your help
I am sure you need to also change the coding in 46 central convenience, or 17 instruments. Not too sure where, but I activated cruise for someone earlier in the week (newish Audi A4) and it needed the 11463 thing doing along with changing a 2 to a 4 in the coding of the instruments (or similar - I don't recall exactly)
You can check the cruise, brake and clutch switches at MB 66.2 and 66.4
how do i get thier.. do i press '1' for engine ?
Aha.. anyone know more about this ??
Yes.
Engine.
Measuring blocks Group 66.
2nd and 4th fields
Yes.
Engine.
2nd and 4th fields
ur a star.. thank u
Under normal circumstances, the 11463 login should be all you need for this TDi.
Sorted. much appreciated guys
GOT A RESULT ...........
component reads : 1,91 R4 EDC G000SG 3**2
Extra : ****G41U******19*
Meas Blocks :
brake pedal on : brake pedal 011
cruise control 010001
cruise system 17.0
clutch oedal on : brake pedal 100
cruise control 100001
cruise system 17.0
Cruse button depressed : : brake pedal 011
cruise control 001001
cruise system 1.0
from this its telling me everythin is working then ?
Edited out Chassis number etc
Brake and clutch switches are working.
Take a look at MB66.4 (Engine->Measuring block 66 field 4) for the cruise switches
Press the Up, Down and move the slide switch to all positions.
You can find more info at http://www.ross-tech.com/vag-com/m_blocks/060-069.html
Any fault codes?
If something isnt wired right it should be logging an implausible signal.
Usually after fitting, coding and an ignition cycle it should start working.
Have you wired the four pins into the block under the wiper linkage correctly?
ok. ill try that next
Any fault codes?
No fault codes.
iv wired up correctly.. confused.com . i checked the main red + wire ( main operating button on end of stalk ) and its got continuity through to the ECU. do you think if either of the others are not connected fully it might stop the whole thing working ????
iv done the check now and looks like a poor connection for the 'set/tip down' button on the cruise as im gettin no feedback from it
du think this single fault would cause the whole lot not to work ??
goin to check the wiring thursday when iv got time
