ED30: Front ARB Size
Hello - can anyone confirm what size the front ARB is on an Edition 30? Is it 24mm?
And as a possible bonus, what size the std fitment is to my lovely Elegance? ;)
Cheers,
Steve
Cheers,
Steve
Steve, Whiteline list upgraded front ARBS for the Mk5 Golf as 22mm & 24mm here-would that indicate the standard is less than 22mm, even on an E30? I'd hazard a guess at 18mm standard & that the Octy is the same? I have been known to be wrong though... :D
My Neuspeed rear ARB is 28mm & it's the biggest I've come across for the rear (Oooer... :giggle:), so I'm guessing that 24mm is about the thickest front ARB about??
Just my 2p's worth!
Bear in mind a thicker front anti roll bar will cause more understeer if its not done at the same time as the rear anti roll bar
Front biased stiffness = more understeer
Rear biased stiffness = less understeer
Sent from my MZ601 using Tapatalk
Preaching to the converted, but thanks ;)
