Bolero - Mobile Phone
Does anyone know a way of keeping the preset buttons on the phone settings on the bolero, as every now and then i lose my 5 preset buttons even though i use the same phone in my car and no other bluetooth device ?
Anthony
I would be interested to know this as well, as my Columbus does exactly the same :(
When you set up your presets, did you 'pick' them from your phone contacts? If so, that might be the problem.
Some people have found that it is more reliable to set the presets up manually, ie tap in the name and phone number from the Bolero/Columbus keypad. The problem might be caused by the phonebook being a little slow to load when you connect your phone. Bolero/Columbus looks for the preset, can't find it, so gives up. If you do it manually, it is held at the Bolero/Columbus end, so should always be available.
i do type them in and they still go for some reason ??????
