where can I get the new fog light with DRL?
I noticed that the new superb fog light has LED DRL beside it.my car is the old version.I want to buy the new fog light to replace the old one.
but where to buy?
It's not LED drl, just ordinary 21w bulb which can be switched to a LED bulb.
Where to buy? Ebay maybe?
Not seen them on eBay, but a dealer could supply them, or a breakers possibly?
Don't forget you will also need the bulb holders and then you will need to run the wiring loom back to an ignition fed live power supply, not a cheap or 5 mins job - but possible.
look at this.
The ordinary 21w bulb is clearly there,not running.
beside it ,an additional bulb,maybe LED,is shining.
look at this.
Those are the later DRL/Foglight's (that the OP does NOT have have though)
The bulb that is lit up in the photo is an LED that has been replaced, the unlit bulb is the foglight bulb.
I have the new DRL. But it's NOT LED. It's an ordinary 21w bulb as written here earlier.
But I have changed it to LED bulb with Canbus support.
Edited by Dekagon
