Bluetooth Retrofit
Hi All
I have retrofitted 5K0 BT module to work with Bolero and it works fine without coding. Thank you for the excellent guide. I have moved all fixings and adapter to left side ie behind glove box as there was little space for them to go behind stereo unit. However did not connect radio antenna cable as there was not enough length unless I split the antenna cable from other cables as many of them were taped together. Is there any adapter or cable to extend the connection or those who have retrofitted them did you split the antenna cable from main cable bundle?
Edited by gizmob
When I retrofitted MDI I peeled back a little of the loom binding to make the antenna lead long enough
Thanks Juan27
