mk4 golf hub on fabia vrs?
im in need of a passenger side front hub does anyone know if a mk4 golf one would fit? and off what model of mk4 golf, i.e. 1.9tdi etc etc if it does?
I wouldn't like to think it would.
You can use the PD160/FR Ibiza though from memory, from same kind of era.
Nope, different chassis and suspension so no it won't.
anyone have a vrs hub around, nearside. could really be using it if you do
Would the hub off a lower spec model fit?
Only the 2.0 petrol from memory. All the others don't have the interchangeable brake carriers. The carriers are incorporated into the hub (the ones that use the FSIII 256mm front braking setup)
