Crankshaft Speed Sensor location
Octavia vRS 2006 2.0TFSI cutting power the power at 5000rpms. Engine fault code is PO321. I have narrowed down the fault to the Crankshaft Speed Sensor.
Does anyone know the location of this?
Can't remember for the life of me if the petrol is at the front of the engine block next to the bell housing or not, the diesel is down behind the oil cooler basically behind the flywheel.
It should have a green plug on it on a short fly lead, it will be down by the oil filter anyway, you can see if from underneath.
  • 6 years later...
Did you find out where it gose
