Nikon Coolpix S9100 Camera
I have for sale a Nikon S9100 that i bought in June last year. It has been used about 6 times and comes complete with original packaging etc.
The only reason i am selling this is because i have an Canon SX220HS and i am going to get a Canon G12 so it is surplus to requirement.
This is what you get:
The Specs are:
Effective pixels: 12.1 million pixels
Image sensor Type: 1/2.3-in. type CMOS with active cell array; Color filter array: RGB filter; Total pixels:Approx. 12.75 million pixels; Recording pixels: Approx. 12.00 million pixels (4000 x 3000)
Lens: NIKKOR lens with 18x optical zoom; Focal length: 4.5-81.0 mm (Approx. 25-450 mm); Aperture: f/3.5-5.9; Lens construction: 12 elements in 11 groups
Focus range (from lens) Normal shooting: approx. 50 cm (1 ft. 8 in.) to infinity (at wide-angle setting), approx. 1.5 m (5 ft.) to infinity (at telephoto setting); Macro close-up mode: approx. 4 cm (1.6 in.) to infinity (at wide-angle setting), approx. 1.5 m (5 ft.) to infinity (at telephoto setting)
Monitor Size: 7.5 cm (3-in.); Number of dots: Approx. 921k-dot; Type: TFT LCD monitor; (Acrylic) cover: Protective acrylic panel with anti-reflection coating on both sides, no air-gapless structure
Storage media: Internal memory (approx. 74 MB), SD/SDHC/SDXC/UHS memory card *2
Vibration Reduction (VR) Image-sensor shift type + electronic type (still image); Other blur-reduction functions: Motion Detection (conventional type), BSS (Best Shot Selector)
ISO sensitivity ISO 160, 200, 400, 800, 1600, 3200 (4000 x 3000), Auto (ISO 160 to 800) , Fixed range auto (ISO 160 to 400)
Interface Hi-Speed USB/PictBridge
Power Sources Rechargeable Li-ion Battery EN-EL12 (1050 mAh)
Battery life *1 Approx. 270 shots (EN-EL12)
Dimensions (WxHxD) Approx. 104.8 x 62.0 x 34.6 mm/4.2 x 2.5 x 1.4 in. (excluding projections) *4
Weight Approx. 214 g (7.6 oz.). (including battery and SD memory card) *4
Movie HD 1080p: 1920 x 1080 (30 fps), HD 720p: 1280 x 720 (30 fps), iFrame 540: 960 x 540 (30 fps), VGA: 640 x 480 (30 fps) HS movie: HS 240 fps, HS 120 fps, HS 60 fps, HS 15 fps
The cheapest new i can find online delivered is £155
I'm selling this, which is pretty much as new condition, for £120 delivered via Royal Fail Special Delivery.
Payment via PPG (Or goods if you pay the fees) or Bank Transfer only. You are more than welcome to ask around if i am trustworthy or not :)
