Problem in reading the temperature outside the car
halo
reading 10c and the realy Degree is 23
or reading -4 and the realy Degree is 19
and in the same day give Correct reading .
where can i found the sensor to clean it
or how can u help me
Look behind the front bumper grill.
Has it affected your MPG? The fuel system needs to know the incoming air temperature to work out how much oxygen the engine is breathing in (there's more oxygen in colder air than in hot air), and then it can calculate how much fuel it needs to add to get just the right fuel/oxygen mix for optimum combustion.
It shouldn't affect the running of the engine. Engine ECUs usually measure the incoming air temperature using either the MAP or MAF sensor rather than these external temp sensors.
thanx for all >
i found it but how to clean it
and did need to clear code from computer
Please help
I change to a new one work tow day and the same problem return agine reading error temp like -5 or -10 but the real temp is 20
What can i do.
Thanx for all
Please help
What can i do.
Thanx for all
Double check the wiring to the sensor
I check the wiring and the connector is good
Any help
Any fault codes?
No
Fit new sensor.
I buy today new sensor work for 4 hour and the problem return read tempe wrong
Any help please
I change the connector and sensor but the same problem
The tempe in the first moment read good but after 30 m read error like this first read 25c after 30m become 1c or -4 or - 10c
Time to visit the dealer i think!
