Knocking from rear. No rear beam on 1Z MK2 Octu
I am trying to work out where the noise is coming from on the rear when going over uneven roads or speed bumps. If it was a mark 1. I would say its the rear beam bushes but the car has independent suspension. Every search I do returns MK1. The bushes are available from TPS for about £5 each.
Question is are they hard to fit like the mark1?
How many components need removing to gain access ?
try the rear drop links
Yep, I'd agree having had a similar issue at the front fixed by replacing the links.
Thanks both. I have no idea what they are. Anyone have a link to write up or an etka diagram?
It's a rod that connects the Anti Roll Bar to the Suspension.
They are about £25 each at the front if you get well made ones and should be 30 minutes labour per side maximum from my experience at the front.
