Advice on renewing rear crankshaft oil seal
I am getting together the kit for replaceing my DMF and also a clutch kit. It will be all be SACHS stuff for my 2003 1.9 tdi 130hp 6-speed hatchback.
My local garage will do the job, they are not Skoda or VAG specialists, but are competant 'generalists'.
The other evening, I noticed a wee drip of oil from the seam between gearbox and bell housing and assumed this was likely to be a leaking rear crankshaft oil seal. I didn't have the nounce at the time to smell the oil to ascertain whether it was gear or engine oil and i couldn't see the colour. ( I will try to do this over the weekend).
So, either a crankshaft oil seal or maybe input shaft oil seal on the gearbox would seem to be the culprit?
Neither of these two items are particularly expensive and I can get both in advance of the job so the garage can be prepared to fit whichever is needed.
BUT - after doing some research on the net. It seems that renewing the crankshaft oil seal might be a highly technical operation needing special VAG tools and know-how because the 'Crankshaft position sensor' is part of the seal? - and this needs specialist technical expertise to remove and particularly to fit. Maybe I have misunderstood the stuff I saw on the net but it seemed to imply that this was a VAG garage job only?
So, my questions are: Can a competant garage refit a new Crankshaft oil seal without too much drama or is this definately a specialist process?
and
Is replaceing the gearbox input shaft oil seal straightforward during the clutch replacement process?
Many thanks for any advice in advance.
Cheers, Terry
Edited by scotsgent
