Columbus GPS signal loss
Hi all,
Just completed first long journey after retrofitting Columbus to my pre FL VRS. Radio came with puck type gps aerial that I fitted under dash as advised. I lost satelites and obviously position after about 50 miles on motorway, showing me as off road. Tried aerial out on top of dash on return journey, initialy seemed better:) but then lost signal again. Wondering if aerial faulty (unit and aerial second hand) or because this uniy has Video in motion, is it interfering with loacation. Any help appreciated.
I had a columbus fitted this week and had some issues initially picking up satellites. It turned out that there was a bit of fluff or debris floating around inside the connector on the GPS cable. It might be worth checking.
Going to pop unit out now back home. Will check all connections. Thanks
