Intercooler or water spray?
I don't really want to mess with fitting a larger FMIC so looked at two other options.
one is move existing intercooler to front?
or more likely is a water spraykit as used on Scoobys etal.
ebay comes up with loads but this looked interesting. This appears a better engineering solution to cool the air.
http://www.ebay.co.u...984.m1423.l2649
Car not rempped but may go stage 1 at a later date.
better off with water methanol injection than a spray on the intercooler
the side mount already has a good airflow to it even better if you do the pikey arch mod
as for water spray if you not going stage 2 then your side mount will be fine left alone imo
I would not worry too much as you are running a std engine. A stage 1 remap will be OK too.
