k04 intercooler pipes
i have just found a full k04 set-up and i want to get it but i am worried about the fitment to my fmic.
At the moment my pipework comes from the pancake pipe to the intercooler and the pipe that comes out (same side) goes up to my inlet manifold. will i need new pipework for this to fit or can i use the pipes i already have fitted?
thanks
simon
On the K04 setup the pipework goes down where your pipe comes up to the throttle body so think you will struggle to get two pipes down same space,
I got a single pass intercooler on mine but i've done the 225 manifold conversion so my throttle body is on the other side now, my pipework is run off pancake pipe at moment but i needed car back on road and didn't have time to run it same as K04 setup
Just use what you got now its is excatly the samé as using the ko3 !!!!!!!
