Kw v1 query
Fitted my kw v1's last night but front is still high?
I fitted the standard spring collar (metal) from the old shocks ontop of the kw plastic spring top plate
Have i booboo'd as other threads suggest this isnt required and would gain me another 5-10mm?
However every other coilovers ive ever fitted utilises the stock spring top plate?
Cheers?
What do you mean jase the top mount?
No not the top mount the metal plate thats on the standard setup on the front that is the first part ontop of the spring? Which then goes the bearing on top then the rubber mount?
I put the metal plate on my coilovers but do i need it as the kw set up has a plastic plate that goes on the spring top?
Hard to explain without pictures :o
it sounds wrong to me buddy
you should only need a top mount and bearing when fitting these
Right ive fitted new top mounts and bearings so on the octy nothing is required from the stock setup
Every other kit ive used before, mk5 golf gt, lupo gti, you need to pinch the top plates from the springs of the stock suspension to fit onto the coilovers!
Looks like im going to be busy this afternoon again :(
Edited by BigJase88
Ah right I get you, yeah only the top mount and bearing is needed from the old setup, nothing else off the standard strut,
On my v1s there was 2 rubber stopper things, they stop it from going down , it say on destructions which to take out for what height :D
Got rid of both to save the trouble :)
Oh poop i have both those rubber stops in? Remove both or 1??
Iirc both are now gone from mine :)
the rubbers are bump stops, they stop the shocks and springs going to their extreme limit of travel to stop them getting damaged and to stop the 'crashing' going through the car, like when you hit a bump in the road at speed. You should keep at least 1 in there.
The kws come complete, you shouldnt need parts from you old shock and spring setup, it sit higher with them in.
All sorted
Thanks for the help
Edited by BigJase88
Thats what they are called :D
There os a giide with them, i think its when you hit 40mm drop the 2nd comes out
Looking sweet in the pic...... Get down you beiatch
