Ride shakes on acceleration
Hi! :)
My Roomster rattles and shakes when I hit the accelerator.
I feel it especially in the floor and steering wheel.
I have balanced the front wheels at a garage.
Can it be the rear wheels who need balancing or can it be something in the front suspension?
Edited by heineoen
Does the shaking/rattling depend on gear you are in?
Does not have to be suspension problem, could also be engine problem, e.g. engine mount or MAF sensor.
Update:
It shakes when not pressing the accelerator also, but it gets greatly improved when I do.
There is no difference witch gear I am in. The shaking does not go away if I press in the clutch.
Update:
If you have a failed shock absorber (damper) it could cause this - push each corner of the car down hard and release quickly - it should rise and fall just once - if it keeps bouncing up and down you have a failed shock absorber.
Check CV joints and bearing, basically if wheels rotate freely and without wobble with the wheels off ground.
