Amundsen Sat Nav sd card
HI New to the forum.
Have a new Octavia with factory fitted Amundsen sat nav. which is working ok apart from not recognising a few uk postcodes but can get around that by entering full address .
Have the CD disk but wish to use the satnav via a SD card.
Not up on sd card info ..... can anyone advise a suitable card and the GB size SD card required.
I will be only using satnav in Uk so hopefully if system allows i will only copy the uk files from the CD to sd card.
No other data will be put on to the card ( ie music) so assume wont require much gb space ?
Any pitfalls encountered copying map files etc from CD to a sd card. ?
Are all SD cards of same physical size ?
Cheers for now
Keppy2012
Hi and welcome aboard.
