Water in OS head light
Swmbo has water inside the OS headlight, the whole of the lens is misted up, yet the back inside the engine bay is dry, there are no visible cracks in the lens, are the light easy to remove to dry them out and would a thin line of silicone sealant work if applied around the seal
I have thought about removing the bulbs and using a hair dryer to dry it out ???
Edited by skippy41
Is the rubber grommet slightly loose? As that is the most likely source of moisture if there is no crack in the lens
skippy
have you ever had a bump at the front,because mine
as leaked over the past few years after i hit a post ,didnt
crack the headlamp but was constantly damp inside.
tried varouis ways of drying,hairdyer through bulb entances
bags of silica gel,even small drain holes through lens.
gave up and brought a new one off ebay for £119
getting it fitted next week
http://www.ebay.co.u...92841962&_rdc=1
btw the headlamp fits 2002 to 2008 models
john
Edited by alfredjohn
