faults on car
hi all ive done a scan on my car with vcds and it produced some faults here is a copy of what it brought up could someone advise me what could be wrong with it? thanks
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 D HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: SKZ7Z0G4390405
Coding: 0203000318070160
Shop #: WSC 73430 790 00000
VCID: 366902E7415C5C9
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
VCID: 73EFFBF312AE091
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R
Component: ClimatronicPQ35 110 0402
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 458B752B0CBAC71
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005165447
Coding: B18C1F111004140000110D000000000000187F073240000C000000000000
Shop #: WSC 35110 377 00155
VCID: 71E3F1FB68B23B1
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 200907 022 0601
Coding: 00055223
Shop #: WSC 35110
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 61
Mileage: 70947 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
OFF
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 71029 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1GCHHQ
Coding: 0020788
VCID: 3D7B1DCB646A8F1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74EDF8EF17A00E9
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 C HW: 1Z0 920 942 C
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0G4390405
Coding: 0003401
Shop #: WSC 28052 576 17507
VCID: 38750CDF4B48AA9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 200907F2000074
Coding: E9807F0F5002022303
VCID: 306534FFA338729
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 71029 km
Time Indication: 0
Date: 2000.00.00
Time: 20:40:26
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 68934 km
Time Indication: 0
Date: 2000.00.00
Time: 13:32:20
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680
Component: RNS-MID H11 3984
Revision: AB001001 Serial number: SKZ6Z7K8171193
Coding: 02000400000000100000
ASAM Dataset: ------------------------- ------
VCID: 2F6737837E066D1
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 46
Mileage: 68928 km
Time Indication: 0
Date: 2000.00.00
Time: 13:47:04
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1204
Coding: 0000756
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 73430 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F04050FC0085F96907C00
Shop #: WSC 73430 790 12345
VCID: 830F2B33C20EB91
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
Component: IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 154
Mileage: 68645 km
Time Indication: 0
Date: 2000.00.00
Time: 12:02:47
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 1
Reset counter: 75
Time Indication: 0
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 397309DB7042B31
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 46
Mileage: 68928 km
Time Indication: 0
Date: 2000.00.00
Time: 13:47:04
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 37770FE34656A51
Address 65: Tire Pressure
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
Have you got the Columbus navigation unit? As three of the fault codes look like the ones you get when you retro fit that unit.
Have you changed the CAN Gateway (19)? It looks like it might have been pre-programmed to a different set up.
Run a scan, then clear all fault codes (DTC's) and allow it to rescan. See what reappears.
Am I right in thinking that 1T0-035-680 is an early Columbus?
If so,:
Go to 19 - CAN Gateway and see that the required items (TPMS, Radio, Navigation, are all 'ticked')
You should find that 47: Sound system disappears as you probably don't have one and 46: Navigation appears.
56 - Radio "Open Circuit Fault' caused by only having one aerial input when two are required. Won't hurt and won't go away (even with a plitter in most instances).
16 - Steering Wheel - 00888 = a faulty switch for the wiper interval speed. Most likely to be dirty. There are tutorials on how to fix cruise control stalks with the same problem and this will probably be very similar.
Without knowing what you have done to the car prior to this scan, it is hard to give you any more information about what may have caused all these faults to 'appear'.
If you have installed a new CAN and / or a Columbus, then that probably accounts for many of these. So, clear the faults and see what comes back by next week.
I had a similar list of faults when scanned, most of them disappeared after clearing all DTC's. Try clearing all and see which ones come back.
i did retro fit the columbus around 3 months ago. i havent put a new can gateway in and im sure its an L which means i wont get battery drain. ive ran another scan and cleared the faults and they came back on and ive checked the tire pressure and im unable to get on to number 65- tire pressure so im thinking there must be something wrong there but dont know what?? also what is the ambience light as thats showing as a fault also??
ill have another go at clearing them and see what happens but im pretty sure the tpms and the ambience lighting stayed on.
Try clearing each controller separately this time.
'L' gateways shouldn't suffer from battery drain.
Have you any internal LEDs? Or have you had a flat battery at any point?
i have got leds in the interior lights is that why its throwing up the ambience lighting fault?
Not 100% sure, but I know LEDs can cause all sorts of issues, even the supposed CAN BUS ones.
Tire pressure is linked to ABS system, so keep an eye on that, you don't want an abs fault cropping up next.
Have you not cross referenced the codes against the RossTek wiki, there's loads of helpful info on there site? Might narrow downt the steering fault too.
The steering one is the 4 way toggle switch on top of the wiper stalk.
I looked it up on the Ross Tech Wiki for someone the other day.
As I said earlier, probably needs cleaning.
All the non-obvious fault codes seem to point to either faulty wiring somewhere or to incorrectly coded modules.
Check fuses, replace LED's with bulbs, then clear DTC's and rescan.
I remember having a 'problem' with fault codes not disappearing: it was down to the way I was saving and rescanning. Clear DTC's module by module then rescan.
It is rare, but I have read about coding becoming corrupted by unknown sources. Perhaps yours has and the modules need to be recoded individually. Just a thought...
Start with 19 - CAN and then go through them all systematically. Make sure you record the settings as they are now and every change you make so that you can always reverse it.
its weird though as everything works fine and never had any problems until ive plugged it in and found the codes??? the tpms works on the dash, the wipers have never stuck and my interior lights work fine??? the only thing ive had is a water leak in the passenger door but that was only once and has never leaked again could it have done something somewhere??
Quite often you won't notice anything wrong with the car as the faults are mostly intermittent.
Perhaps changing the Head Unit has had a knock on effect on some of the other controllers...
Try what has been suggested and see how you get on.
Will do and thanks for the advice
ive cleared the faults and done a rescan and they are pretty much still there so could someome shed some light into whats wrong please??
Thursday,26,July,2012,13:52:47:14811
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 65 72 76
VIN: TMBUF21Z882062125 Mileage: 71640km/44515miles
16-Steering wheel -- Status: OK 0000
Revision: 00H11001
Coding: 0004738
Coding: B18C1F311004140000110D000000000000187F072300002C000000000000
Coding: 00055223
Shop #: WSC 35110
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Mileage: 71488 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Coding: 0020788
Coding: 0000042
Coding: 0003401
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 71644 km
Time Indication: 0
Date: 2000.00.00
Time: 13:52:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 71644 km
Time Indication: 0
Date: 2000.00.00
Time: 13:52:01
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 30
Reset counter: 54
Mileage: 71616 km
Time Indication: 0
Date: 2000.00.00
Time: 14:52:48
Coding: 0000756
Coding: 81801A085283007F3F040F0FC0085F96907C00
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 53
Mileage: 71617 km
Time Indication: 0
Date: 2000.00.00
Time: 14:53:52
Cannot be reached
Coding: 0000756
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 30
Reset counter: 54
Mileage: 71616 km
Time Indication: 0
Date: 2000.00.00
Time: 14:52:48
Coding: 0000144
Cannot be reached
Coding: 0000144
Coding: 0000001
End ---------------------------------------------------------------------
Ignoring the "aerial" faults (because you have a columbus), do you have the optional 12 speaker sound system?
Also, how good is your battery? Has it gone flat recently?
I think the "backup horn" fault was discussed in a thread on here & there was some discussion about it being an alarm issue
battery is good never had any issues i dont think i have 12 speakers just the 8 including tweeters. dont know what sound system is could it be related to the columbus retrofit and i just have to live with that?? the ambience lighting is the leds for interior lights i think so will live with that and i cant do anything about the antenna i know that so it just leaves the interior monitoring system which i have no idea what that is and the tire pressure monitor which i cant even get on??
Ok, so you shouldn't be getting the report for the sound system, as you don't have it, and the TPMS is done via the ABS system. The reason i asked about the battery was that on fault was shown as 12v, and could be a short, or it could be that the battery voltage is dropping and thus you are getting the fault logged. Had this on my old Octy when the battery gave up.
How old is your car? Has the CAN gateway been replaced at all?
just a question if a battery was faulty would it make the car to splutter sometimes when started as i get that reguarly? could the car the columbus came out of had sound system and that i just have to live with that? im not sure about the can gateway not been changed since i had it and its a 57 plate
As it's usually easy to get done, i'd have the battery drop/load tested, but I'd not like to bet that it fixes the problem.
You really need one of the forum VCDS wizards, perhaps who live near you to take a look, but I think you can de select the sound system in the CAN gateway. The problem is however that some of the faults could be coding errors as much as faults, so you really do have to be careful with what you alter to try and correct things. How long have you had it? how many previous owners etc? It could be that a previous owner had a problem and swapped in another CAN Gateway? But you really do need a proper expert to check it over.
How far are you away from Awesome GTI? Might be worth a few quid to resolve it?
i use a place called psi tuning near me they are very good so ive got them to have a look when it goes to have the kw coilovers done
Quick update I've taken it tothe garage yesterday and the tire pressure fault was that it was ticked in can gateway and I don't actually have that at all mine works through the abs apparently! And he unchecked digital sound and all is god now! The only fault that won't go away is the interior monitors for the alarm and he doesn't know what these are so can anyone tell me how to fix this please?
