Dead coil pack?
2.0 FSI Turbo - just changed the fuel pump cam follower and swapped out the PCV from a (suspected knackered) Rev C to a Rev N. I also replaced the breather hose from the PCV to the intake manifold after I snapped the clip when removing.
Car is now misfiring and VCDS shows the following. Am I right in thinking the coil pack on cylinder 1 is dead? There is a slight smell of fuel which I assume is because the fuel being injected into cylinder 1 is not being burned. Could it be another problem? Engine light came on initially but nothing since clearing the codes.If I swap number 1 coil pack over with another, is this going to cause any issues? Just thought it would help me diagnose the coil pack if I swapped coil 1 with coil 3 and got a misfire on 3.
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 A HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: SKZ7Z0F4012513
Coding: 0203000318070160
Shop #: WSC 00191 264 15243
VCID: 336F3044522E491
Fault Found:
004949 - Cylinder 1 Ignition Circuit
P1355 - 004 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 107207 km
Time Indication: 0
Date: 2000.00.00
Time: 07:25:10
Freeze Frame:
RPM: 460 /min
Load: 36.1 %
Speed: 0.0 km/h
Temperature: 17.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
Readiness: 0000 0000
