Having problems with my dpf delete. The mapping does not seem to have wiped away the DPF pressure sensor readings...Getting two errors: DPF Differential Pressure Sensor implausible signal and Exhaust pressure sensor implausible signal.
I had the DPF delete done by a respectable team (well known on this board). Any thoughts? Do I need a different map to get rid of these or could it be a sensor problem. I would have thought the DPF differential pressure sensor should be gone from ECU?
you need to contact the said mapper and ask them that should be the first thing you do
Thanks! Mapper recommended replacing sensor. Errors have nothing to do with DPF delete and are errors related solely to faulty sensor! apparently quite common on Skodas....sensor replaced and light remians off...
Happy days and all sorted in time for Christmas, how is the car running for you now with it all complete?
