Half Way Through....
........the fitting of my new stereo.
All the difficult stuff has been done.
The power cable has been fed through the bulkhead , I have the scars to prove it.
All the leads have been run to the boot (power , 3*RCA , CD bus , amp remote) and the trim is back on.
One front door speaker has been replaced , and the stereo has been tested.
The CD changer is in place in the boot on a custom made bracket bolted to the wheelarch.
Still to do
Replace 2nd front speaker
Connect power cable to battery and amp.
Bolt amp to rear seat & connect up.
Refit carpet around CD Changer
Connect up stereo & changer.
Drill holes in rear seat back for subwoofer brackets.
Hmmmmm , all good fun.
Sounds like a fairly big install.....bet it will sound absolutely great when complete,lets see some photos when all done
Its sounding pretty good with the new Kenwood fronts and the standard rears at the moment.
The changer is now connected and the carpet back in place.
All I have left to do is connect the +ve feed to the battery and bolt the sub down.
Pics will indeed follow.
