v6 2.5 tdi egr blocking .......?
Has anyone done it to their own cars or know how to do it step by step ...
I've got the plate from eBay to block the egr but do I block the vacuum pipe off from both ends as well ????????
Do I need to get it re-programmed by vag com?????????
How good is it for a long journey? ?????????
If you do this the injection timing will be too advanced mid-range and will sound like a tractor.
To do it properly you need a suitable re-map. Send me a p.m. if interested, I can sort this for you if you are anywhere near NW9, as I go there periodically.
VCDS/VAGCOM can only reduce EGR, not switch it off completely.
Why do you want to block it, do you have smoke, or is it laggy? Long journey fuel economy should improve if done well, but short journeys, especially in winter, will result in slower warm up, hence a bit worse fuel economy, plus you will have to wear a jacket too.
I work in nw10 Harlesden area so can pop out to meet you somewhere
Will come with coffee for exchange for your info on this matter and always happy to
See another briskodian running v6 tdi auto
Let me know when you around 07875171745
