Need a help here....
Hello Folks
I just wanted to install separate set of LED DRLs...... I have bought the whole kit including relay. But I am unable to route a wire through engine firewall to the cabin.... Is there any easy n safe way of running a wire to cabin from engine bay.......??? Replies would be welcomed and appreciated.
Regards
Alam
Remove the battery & tray then the glovebox. There is a rubber grommet in between with 3 'nipples' through which you can pass wires.
Easiest to go from inside to engine bay.
+1 on the three nipples but there isn't any real need to remove the glove box. Take the foam pollen filter cover off to gain access and use a stiff wire to guide the wires through from the engine. I used plastic strimmer cord/line. By the way you will have to cut the end of the nipple :-)
