turbo and noise
my 2008( before face change model late 2008) superb had a new turbo fitted 6 months ago as it cut out when going up hills also sometimes when turning it on first time the turbo wouldn't come on, also eml light would come on. also when turning off engine a whining noise from the air reserve valve front bottom of engine.
all worked ok for a week then turbo would sometimes not come on and eml light would come on but no problems going up hills or under load.
re did the wiring from the ecu to turbo
replaced air mass meter
n75
map sensor
the air reserve sensor mentioned where the noise comes from.
g31
no more to change
has not cured the problems other than the eml light on permanently now
turbo doesn't come on when first turned on and whining noise FROM AIR RESERVE VALVE when turning off.
i think i have covered it all
would any one have any suggestions please
many thanks graham
A proper diagnostic check using the dedicated VAG software or an accurate clone. Box swapping is futile and expensive.
rotodiesel.
