problems after changing power steering pump
Please see below scan, changed my power steering pump and more lights on the dash than before has any one got any ideas,
VCDS Version: Release 12.12.0
Data version: 20130910
fastfitz
Saturday,12,October,2013,12:36:08:24589
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBWU46Y544006152   Mileage: 122750km/76273miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 LA
   Component: Auto-Tune   G000SG  5405
   Coding: 00102
   Shop #: WSC 13765
   VCID: 61C2A27EEB29A716FBD-4B00
   TMBWU46Y544006152     SKZ7Z0C2212441
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
            P1653 - 35-10 -  - Intermittent
Readiness: N/A
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ASR.lbl
   Part No: 6Q0 907 379 H
   Component: ABS/ASR 5.7 FRONT   V40
   Coding: 00188
   Shop #: WSC 13765
   VCID: 42804DF24EEFDC0EC27-5120
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            30-00 - Open or Short to Plus
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: EAD04552961F644EAA7-5120
1 Fault Found:
00819 - High Pressure Sensor (G65)
            31-00 - Open or Short to Ground
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25738
   Shop #: WSC 13765
   VCID: 3C7C330A2C0BAAFE88B-5120
No fault code found.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601 A
   Component: 11 AIRBAG VW51      0008
   Coding: 12593
   Shop #: WSC 13765
   VCID: 1E38D9829AD7D8EE86F-5120
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
            32-00 - Resistance Too High
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 970 S
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 20421
   Shop #: WSC 13765
   VCID: 4D9A6ECE87B113762F5-5120
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 0031 GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0E4573AB0C39E9EE43-513C
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 10120
   Shop #: WSC 73788
   VCID: 2F661446ED7D41663D9-5120
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            79-00 - Please Check Fault Codes
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 33 Komfortgerát     0002
   Coding: 00066
   Shop #: WSC 13765
   VCID: 3D7A3E0E3711A3F6BF5-4AE6
   Subsystem 1 - Part No: 6Q2959802A
   Component: 33 Tõrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q2959801A
   Component: 33 Tõrsteuer.BF TFK 0004
End   ---------------------------------------------------------------------
Nothing there to do with the PAS.
You have an issue with an ABS sensor and/or it's wiring.
Also your AC pressure switch is logging a fault, probably low on gas.
Fault code with the oil temp sensor is an odd one, you don't have it so I would think that's a coding issue.
Drivers side airbag igniter is either the airbag has been off with the ignition on or maybe the contact ring is faulty.
Pas light is on
Abs and Asr lights on.
Is there anywhere the wiring gives trouble as I have changed the sensor
Maybe you need to clean the Reluctor (I think that's what it's called) ring that the sensor looks at with a cotton bud dipped in methylated spirits.
If it's a front wheel, jack up, put on full lock, at the back of the hub unit you can see a shiny ring, rotate the wheel and apply the cotton bud and clean.
If it's a rear, there must be a ring there also, do as above.
It worked OK for me and cured the fault.
DB.
Edited by mogwye
The ABS fault is open short circuit to positive so it's either unplugged or the wiring has an open circuit. A dirty sensor or faulty reluctor would give an implausible signal issue.
I expect that you have disturbed a multi-plug or earth to get so many unrelated codes.
SN
Absolute torture.
Looks like a stripping session to find a broken wire. Do these give problems around the loom on the front chassis leg below the abs pump
Found the wee bugger, corroded wire near the abs pump, where the wires leave the main loom to go to the abs unit. I'm much happier now, even though I spent all my spare time for a week to sort this out.
