central locking ,etrol cap and dead locked door problems
Hi all had a look around find so codes but unsure if I have it right
01331 drivers door module
0928 switch driver side implausible
0929 switch passage front
0930 switch left rear
0931 switch right rear
0944 heating mirror
0943 heating mirror
17608 boost pressure control valve mech problem (car has a hks valve fitted running .8psi on hks gauge )
problems I having run mirrors not moving or heating
all doors not locking unlocking on key or fob (key opens drivers and ind lamps flash)
but boot is unlocking/locking on fob
dash door lamp is on when boot is unlocked
dash door lamp coming on with passage doors when open and inside lamp coming on when open doors on passage side and when unlock boot
no front door lamps working or alarm lamp
petrol flap motor is not opening
all power windows work
not find any blow fuses
check drivers window plug its clean with all pins there
have find damaged to the door lock wiring plug i.e. pulled out of the housing
so if I replace this unit would it fix all the codes
Haven't you got an edit button down the right bottom side of your screen to edit it?
