Door lock part compatibility
Skoda Fabia 2006 1.9SDI
After replacing my right rear door lock, now same problem with the left one.
According to my Skoda dealer, the proper serial numbers of the said part are:
5J0839015
6Y0839015
6Y0839015A
However on an online ETKA service it states also 3B4839015.
How can I be sure that also 3B4839015 serial number will fit my Fabia?
it's possibly year dependent as there was a small modification the the rear door locks I believe. Older ones had a white catch for the locking rod (from the button on the door) while later variants had a red catch and the fitment was slightly different I believe.
Your dealer will have used your reg/ VIN to identify the correct Part number.
Hi pavinjo
"After replacing my right rear door lock, now same problem with the left one.
5J0839015
6Y0839015
6Y0839015A".......... These numbers are for cars WITH central locking.
"However on an online ETKA service it states also 3B4839015."........... I can only assume that this part number would be for cars WITHOUT central locking.
Use this link and see if you agree - http://www.partsbase.org/skoda/fabia-fab-eu-2006-83900-door-lock-inner-actuator/
Hope this helps.
Alan
Thanks guys, makes sense.
First will try to see if said lock can be repaired before ordering an replacement.
Best regards
