Fabia Mk1 2000 1.4 16v leaking water
Hi.
I thought a new polen filter /Cabin air filter solved my water problem. There is still coming water from the polen filter. I am pretty sure, that it is installed correctly. I have talked with my mechanic. He mentioned that it could be the drain holes underneath the wipers. I have looked at  it and search on this forum. It seems, that i have to remove the wipers. Is there someone how have a guide to clean this drains holes or picture where the are located ?
Hi.
drain holes are located under the scuttle panel, far left and far right. I use a thin bottle brush to poke them through.
Thanks found it. Holy ... there was many leaves there. When I removed them  there was a big shower of water.
It is amazing how such a annoying problem can be solved so easy. My mechanic will have charged me for 2 hours. That is OK but wouldn’t show me where the drain where. Thanks for your help.
Happy Christmas every body
Regards
Kristian
