ABS/ASR lights on
Hi,
Got a problem with an Octavia. ABS and ASR lights are illuminated and after swapping the ABS pump with a Leon it displays the same fault. Here is the VCDS log. Also any ideas on the engine fault?
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Wednesday,08,January,2014,15:40:17:62800
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBHS21ZX72122515   Mileage: 444730km/276342miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  9251
   Revision: --H06---    Serial number: SKZ7Z0G4047191
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6AF521ED458AB94E2A7-803F
1 Fault Found:
005746 - Coolant Fan Control 1
               P1672 - 000 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 444731 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:19:20
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11000011
                    Temperature: 48.6°C
                    Duty Cycle: 9.7 %
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0000641
   Shop #: WSC 06441 785 00200
   VCID: 3FA3A0B96E88ECE6AD9-806A
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
            012 - Electrical Fault in Circuit
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   Shop #: WSC 00000 000 00000
   VCID: 3449FF9557CE3FBE40B-8061
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004723801
   Coding: 00880F030004140000110D000000000000087B075C0000
   VCID: 6BFB24E94A70A046511-803E
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 090207 022  0601
   Coding: 00055223
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD11ETPX
   Coding: 0020788
   VCID: 3D5FDAB16484FEF6BF5-8068
   Subsystem 1 - Serial number: 6332MSME154E793FT
   Subsystem 2 - Serial number: 6342MSME16154C78G
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   VCID: 74C93F95174E7FBE80B-8021
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 D    HW: 1Z0 920 912 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0G4047191
   Coding: 0002401
   Shop #: WSC 00999 444 64523
   VCID: 364DC59D41B22DAE7EF-8063
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 130207F2002112
   Coding: 3D3F034007002303
   VCID: 2F43F0F9BEE81C663D9-807A
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 3851CBA54BA6DBDE6C3-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.068 H07 1806
   Shop #: WSC 73430 000 90108
   VCID: 354FC2915CB426B6775-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F04850540085F96907CA0
   VCID: 832BEC49C2E0C806091-80D6
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 3957CEA170ACC2D693D-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3G0143322
   Coding: 0000402
   VCID: 2E7DEDFDB9E2156E36F-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 3753C89946B8D4A6659-8062
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
End   ---------------------------------------------------------------------
Its going to blow up. Anything else you want to know, just ask.
