Power for sub
My mrs bought me an sub for Xmas and I need to get it wired in. Problem is I can't find an existing route to get through the bulkhead to battery. Any suggestions would be welcomed! Pictures would help too ;-)
There's a grommet that you can cut a hole in. From inside the car it's behind the glovebox and from the engine bay I believe it's under the pollen filter.
Where in the country are you?
One under the plastic scuttle panel on the drivers side aswell
Or up in the nose shape thing u can see when look down :D
Mine fed through that from the battery, inside the black plastic wire cover and into scuttle so was all hidden ;)
Im intrested in this too pics of how youve done yours will be great
i run a sub also and i wouldnt go through drivers side
Passenger side I meant......I'm a thick ****! :)
I'm in Lincoln, I'll have a look tomo. Only just seen replies...
Cheers guys
Anyone got a decent wiring kit lying around as ive had a sub given me
Urgh, still didn't have time to do it today, I ran out of light... Must try tomo!!
There is a relay box on the bulkhead, lift it up and move to side and pull firewall sponge back from side of strut tower and there is a big grommit that leads to behind glovebox in car, i have 2 4 gauge power cables running through it
Mine went from the battery and was hidden in the black plastic loom cover, through a grommet under the slam panel.
Right the fella's I am failing at step one here! How is the cover strip suppose to come off? I don't want to just rip it off, I can see where I want to be I just can't get to it! Also, where behind the glovebox will it be? I just have a mass of crap behind it and a load of sound proofing!
Who wants to come and do it for me before I throw my teddies? Cars are so delicate compared to aircraft.... :-/
By cover strip I mean the fairing at bottom of windscreen behind bonnet seal
If lifts away at 90 degrees from the windscreen
