Michi OCC question
Should mine have any type of fluid in like a normal amount it would collect after 3 months or however long ive had it?
I have undone the drain plug about 3 times since I've had it and no fluid...
The bottom pipe to the OCC is dirty and clearly has had vapor through it but my top pipe is bone dry
Just want to know as I thought it would have collected some watery oil stuff by now...
anyone?
Sounds like you may have connected pipes up wrong
The top pipe is the inlet, the lower one the outlet
eg the top pipe should be the dirtier
Some engines don't seem to produce much water/oil vapour though, whereas some seem to cough out loads of water/oil
Even after the wettest/dampest weather I've never had much content
