brake pad sensor light
hi guys just changed all discs and pads all round on my vrs but when old pads came off they had the wear sensors on front but as i have fitted ferodo ds2500s they came without the wear sensors now the light is stuck on anyone no how to get rid of the light all help much appreciated
Yeah, change the current pads with sensor ones  :D
Just connect the pins up with a paperclip?
Use the wear sensor plug off the old pads and join the 2 wires and tape it up.
Can also be disabled via vcds.
Easiest way is if you have vcds,you just change the coding in the instrument cluster.
