Help
Doors lock unlock at will windows go up and down even when car is locked and unattended drivers door switches operate different windows to indicated battery going flat can't identify fuses or relays to remove to stop having to lock car as rear estate lock key is seized then disconnect battery before it unlocks
Car is a 51 plate Octavia 1.9 diesel estate auto
Fred
Hi fred, i would start by checking the door control unit inside the drivers door. It has a habit of filling with water and causing trouble
Thank you will have a look I think we may have had a little rain lately so could well be my problem
